Re: super m ta starter problems
Posted by CNKS on December 29, 2012 at 13:41:06 from (216.144.104.128):
In Reply to: super m ta starter problems posted by wilson ind on December 29, 2012 at 12:13:38:
The number and 3 bolts and 6 inch body are correct for your starter, I can't tell you what is wrong. However, I have a Super M with fire crater pistons and the same starter as yours, currently under restoration. I bought it a couple of years ago with the original 6 volt system, I will leave it that way. The long cable which I believe is original is 2 gauge. 99% of the people on this forum will say that 6 volt requires 0 or 00 cables, even on the smaller tractors. I have not found that to be true. Keep all of the connections clean and be sure that there is not corrosion under the insulation close to the connections, and with a good starter you will be fine. I really doubt if it was converted to 12 volts. Take the starter to someone that knows what they are doing and get it checked out.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
