Re: 460 hydraulics sucking air.
Posted by Heat Houser on December 29, 2012 at 17:04:14 from (69.66.35.73):
In Reply to: 460 hydraulics sucking air. posted by CJ Johnson on December 29, 2012 at 13:55:04:
Are you sure it is not the filter and bypass screen plugged already? You have a center section that is "new" to you and a 17 GPM pump. You may have sucked up debris off of the bottom of the transmission plugging your filters.
Wouldn't hurt to check and confirm that it is not.
Air should work out after a few cycles. Do not hit the ends of your strokes while trying to get the air out. Fuel, (aerated oil) pressure, (1200 psi relief) equals possible burning of the piston seals. Diesel engines can ignite fuel at 400 psi or so.....your hydraulics at 1200 is a bit higher than 400. Have seen this on large excavators, burned seals.
