Re: gas ih 560 carb keeps freezing up
Posted by old on December 29, 2012 at 17:53:42 from (209.86.226.19):
In Reply to: Re: gas ih 560 carb keeps freezing up posted by peter29 on December 29, 2012 at 17:22:42:
Open the main jet up just a little bit till you find the spot that works. When it is cold out some times you need a richer mix to run well. You can also make a side cover to help hold in heat. Some people make a cover from foil so as to help hold more heat in the area. That is why on the older cars they had a tube that went from the exhaust manifold into the air cleaner intake to pull the warm air into the carb so that carb icing did not happen but on a tractor doing that would not be easy
