The tube I am referring is about three inch's long and is inserted into the suction port of the pump. The tube has a lip seal on it and when you install the pump onto tractor the tube enters the counter bore in tractor. The oil from the filter is pulled right from the filter, through the tube into pump. If that seal is hard, or not positioned properly or damaged the pump will suck air. You can see the tube from filter side but can't tell a lot about it. I have seen so many of them not positioned properly and or needing replacement when the pump is replaced. They are kind of spendy so many just don't replace them. Not all pumps are the same dimensions on back side so that is why t he seal has to be adjustable by sliding on the tube.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
