Re: What to look for on an A
Posted by gene bender on December 29, 2012 at 23:03:53 from (67.55.227.74):
In Reply to: Re: What to look for on an A posted by RTR on December 29, 2012 at 21:43:06:
The manual lift for the Farmall A goes with the implement and is not a standard part of the tractor as the lifts are different for all the implements. So the tractor will not have a manual lift as standard equipment that goes with the tractor. There were two types of lifts manual and exhaust lift for the different implements. Loose steering is easy fixed but do check for a crack behind the carb as thats where they cracked when not enough or no Anti Freeze was in the cooling system allowing the block to freeze.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
