Re: gas ih 560 carb keeps freezing up
Posted by gene bender on December 29, 2012 at 23:23:59 from (67.55.227.74):
In Reply to: gas ih 560 carb keeps freezing up posted by peter29 on December 29, 2012 at 16:40:05:
When the humidity level is such even in warm weather the carb can get frosty. Some place a shield over the carb so the manifold heat can keep it from freezing. We always had a heat houser so i never seen and frost while it was on but inlater spring and fall it would draw frost.
