Re: 300 ignition voltage question
Posted by Janicholson on December 30, 2012 at 07:45:41 from (74.60.94.18):
In Reply to: Re: 300 ignition voltage question posted by Zachary Hoyt on December 29, 2012 at 15:54:52:
I assumed you would put the (for use with external resistor) type coil on it when using the diode idea.
If the wire from the starter switch was 12 gauge to the diode, it sure would limit the voltage drop on startup. I am not too happy with your battery voltage readings. I also assume it has at least #2 gauge battery cables. Happy New Year Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
