Re: won't start
Posted by David G on December 30, 2012 at 08:18:25 from (205.215.206.18):
In Reply to: Re: won't start posted by RICK IN VERMONT on December 30, 2012 at 08:15:20:
If you do not draw at the carb, then it is an intake leak, compression, valve timing or valve clearance issue.
I would bet valve timing or clearance if you are hearing noises in exhaust.
Check the clearances again.
