Posted by old on December 30, 2012 at 10:56:31 from (209.86.226.27):
In Reply to: Re: won't start posted by John G. Hasler on December 30, 2012 at 08:48:48:
With the air cleaner hose off try to start it but as you do hold your hand over the carb air intake. You should both feel a good suction there and also when you remove your hand it should be covered with gas. If you do not have both then your compression is to low as in no suction or if no gas your carb is clogged some place. Note if you do that it also might try to start. If low suction put say a table spoon of ATF/gas mix in each cylinder and try to start it. The ATF/gas mix 50/50 will up compression and also burn like gas and may end your problems
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
