Re: M won't run
Posted by Greg K on December 30, 2012 at 11:53:27 from (75.107.96.58):
In Reply to: M won't run posted by Makin hay on December 30, 2012 at 11:48:49:
Maybe float needs adjusted/readjusted. Needle and seat could be sticking. Maybe not enough fuel from the tank, pull the line loose and you should have a good flow about as big around as a pencil(the inside of the line). Then get to checking the coil if these do not change anything, A bad coil can cause this also.
