The stroke of 5th is less than the others, but the problem is probably one of three things. Input shaft splines and 4th 5th slider gear splines are worn and tapered from continual rough grinding into 5th from 4th. Worn or failed intermediate (pilot) bearing between input and output shafts (near the 4th 5th slider location) Ball and spring on detent weak or broken. All these repairs require removal of the trans top. The first two require a split of the tractor to get at the problem (IIRC). The tractor usually does not have this issue because the TA allows starting in 5th TA then going to direct. Jim Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
