Posted by old on December 30, 2012 at 13:29:26 from (209.86.226.34):
In Reply to: M won't run posted by Makin hay on December 30, 2012 at 11:48:49:
Remove the carb drain plug, let it flow as long as the engine ran then a minute or 2 more. Catch the gas so as to look for dirt/rust/water and so you can use it. If the flow stops before or slows way down before that 5 minutes or so then work you way back till you find where the clogged line is. Also if you find that is good then start it up. The moment it dies check your spark. DO NOT turn off the ignition check it before you do that so that any part to is heating up /going bad will still act the same. Spark has to be a blue/white and jump a 1/4 inch gap or more
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
