Re: Brake assist for M
Posted by Glennster on December 30, 2012 at 17:21:02 from (99.90.9.201):
In Reply to: Re: Brake assist for M posted by Fritz Maurer on December 30, 2012 at 15:25:12:
Bet its a gas gauge. I have a couple sticks like that in the barn for the same purpose. Way better than using a butane lighter!!!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
