Re: 1975 Farmall 140 - Only Fires When I Let off of Starter
Posted by El Toro on December 30, 2012 at 18:57:40 from (108.3.143.30):
In Reply to: 1975 Farmall 140 - Only Fires When I Let off of Starter posted by RTR on December 30, 2012 at 18:05:21:
You may have a defective ballast resistor. I would check the battery voltage while cranking to see how low your voltage is. Check the specific gravity in each cell using a hydrometer. Should see 1.280 on a fully charged battery. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
