Could be the shunt wire that bypasses the resistor when you hit the starter is broken or loose. Run a jumper wire from the positive post on the battery to the positive (+) terminal on the coil and then hit the starter. If it fires right off you've found the reason for the hard starting problem. Then you'll have to start tracing the wiring from the coil back to the ignition switch until you find it. Could be a bad switch or a wire that's vibrated off of the switch. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
