Re: 1975 Farmall 140 - Only Fires When I Let off of Starter
Posted by RTR on December 30, 2012 at 19:11:48 from (98.83.136.199):
In Reply to: 1975 Farmall 140 - Only Fires When I Let off of Starter posted by WiJay on December 30, 2012 at 18:05:21:
I don't see a resistor anywhere on this tractor. The coil isn't readable as it is rusty and dirty. I don't know if it's a coil with internal resistor or not. The wire goes straight from Key Switch to Coil (+), then wire from Coil (-) to Distributor.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
