Posted by jimb2 on December 30, 2012 at 19:31:28 from (174.114.182.155):
In Reply to: 424 axle oil leak posted by warren woodrow on December 29, 2012 at 17:16:17:
Hi Warren, The B-414,434,424 models were designed to use 90W gear lube in the transmission/differential. Some industrial models like 3444 used the transmission as a hydraulic reservoir with Hytran instead of 90W.
There is nothing wrong with using Hytran in the 424 transmission/differential but be prepared for some leaks. In fact Hytran is probably better for moisture conditions and operation in cold weather. I can remember using our 434 in -25F weather and you had to leave the transmission in the gear you wanted to use the next day. It would take a good half hour of running before you could shift gears easily.
Today's Featured Article - The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
