Posted by pete 23 on December 30, 2012 at 19:36:52 from (74.32.229.189):
In Reply to: Broken jet posted by Bkpigs on December 30, 2012 at 19:12:55:
First off, measure the size of the hole in the jet right down to the nitty gritty so you replace it with proper jet. That is one place an eze out does sometimes work, and you won't break it off. If that does not come out, as rusty as that is , I would soak carb in muratic acid if body is cast iron, not pot medal. That will cut the rust out of all of it. About 20 or 30 percent acid to water. There are taps available to restore damaged threads for those jets.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
