Re: Brake assist for M
Posted by Notjustair on December 30, 2012 at 19:58:17 from (174.229.72.196):
In Reply to: Brake assist for M posted by Mark Poss on December 30, 2012 at 11:08:13:
The last M I bought had a cool brake setter on it. It was clearly aftermarket not some homemade thing. There is a bar made of round stock with a finger to set the holder against the teeth. It goes over to the clutch side and is bent up so that you step on the brakes and they step on this lever over under the clutch pedal. Slick as snot. I hadn't seen anything like it but it is the best thing I have seen.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
