Re: 1975 Farmall 140 - Only Fires When I Let off of Starter
Posted by Owen Aaland on December 31, 2012 at 10:06:59 from (216.47.32.148):
In Reply to: 1975 Farmall 140 - Only Fires When I Let off of Starter posted by RTR on December 30, 2012 at 18:05:21:
The Carter and Gruenwald wiring diagrams only show the wiring for the earlier tractors used with generators.
The parts listing shows a magnetic switch used for engaging the starter on tractors that used alternators. The magnetic switch includes the bypass terminal used for supplying additional voltage for starting. Like Pete posted earlier the resistance used for the coil will be built into the wire that runs between the key switch and the coil.
If you look at the wires attached to the coil I think you will find a connector with two wires coming from the rear of the tractor and just one wire going to the distributor.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
