Re: 300 clutch installation
Posted by sflem849 on December 31, 2012 at 13:42:18 from (69.197.84.39):
In Reply to: 300 clutch installation posted by MoMike on December 31, 2012 at 13:21:53:
Sorry, I don't have a hundred series tractor. There are a bunch of "standard" torques on the internet for different different bolts/thread pitches/etc. I use those for critical applications when no specs are given in the manual(s).
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
