Re: Frustration
Posted by Janicholson on December 31, 2012 at 18:30:59 from (74.60.94.18):
In Reply to: Frustration posted by Zachary Hoyt on December 31, 2012 at 17:57:44:
If it is pulling a vacuum on your hand, it is going to have compression. If the spark is getting t the cylinders at TDC it is going to be assumed that the system is correct. Two things then stand in the way. one is fouled plugs. They might even look perfect, but need to be heated with a propane torch till the little ground electrode is very hot, and the plug smokes some. Put them in warm, with a rubber hose to keep your hands from getting toasty.
Use a squrt oil can with gasoline (2stroke is great) in it to put two pumps into each cylinder before the plugs go in. If it fails to keep running then it is some major plugup in the carb. Merry new year, and I hope this helps. Jim
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
