Changed up a few things today. Moved the oil filter to the inlet side of the tank, raised the 6". Got rid of the hy-tran, only reason used it. Had some left over from 560 oil change. Hy-tran is like snot in the winter. Put in everyday hyd oil, nice & thin. Its only going to run the ram on the blade ever. Upgraded the pump also, went from 12 to 20. The 12 needs 4000rpm to make 12. Since this engine is lucky to get 1400, the 20gpm max input is 2200rpm with pressure of 2000psi. Made up new suction line, changed some fittings. Poured oil in, rev for couple mins to get rid of air. Then reved up engine. Old man was beside tractor. He jump when the blade moved. Laughed to myself, blade has never moved this fast in its life time. P/auto also sells a different seal to convert this pump into a motor. Im not going to reverse the pump, but like the idea of a seal with a back washer. For the heck of it I put it in. Then replaced the spool valve, another just incase. Plowed snow down the drive way, no leaks so far. Really impressed with the response of hyd's & speed. Hopefully its fixed for awhile. Found punp flow calcuations, its going to do 13.75gpm. Image this in perfect world settings. I have no idea if old engine is doing max rpm anymore, if my lines are the rights side, etc.
This post was edited by Redturbo at 22:28:22 12/31/12.
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y
... [Read Article]
Latest Ad:
[More Ads]
