Re: Help! I'm stumped - Farmall won't crank
Posted by H MN on October 31, 2000 at 08:10:10 from (63.253.194.230):
In Reply to: Help! I'm stumped - Farmall won't crank posted by Keith Seymore on October 31, 2000 at 07:43:28:
Keith: Every try resulted in NOT turning the engine over more than 1/4 turn? Maybe not the starter at all. Maybe your engine has a serious internal problem. FirstTry a hand crank? Maybe a need here to Pull plugs and check compression? Careful here if there is internal damage other than the starter and a hand crank is a safe quick check. If thats ok then try pulling to start to make sure the engine is ok. Then back to the starter if engine is OK. harvey
Post A Followup
: Re: Re: Help! I'm stumped - Farmall won't crank
