Hang the clutch disc/pressure plate assembly on the splines and roll the tractor halves together. After bolting the halves up, just bolt the pressure plate to flywheel thru the hand hole underneath.With this method, you only have to align the input shaft into the pilot bearing. Way, way easiest way by far to assemble. Mark
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa
... [Read Article]
Latest Ad:
[More Ads]
