Re: F 20 mag
Posted by Old-F20 on January 01, 2013 at 18:04:55 from (71.7.101.5):
In Reply to: F 20 mag posted by outsidersag on January 01, 2013 at 18:01:32:
pull the magnet off and wire brush any rust and scale off thats built up between the magnet and the case. make sure you put it back on the same way, for polarity reasons
magnet might need to be chraged too, wire brush it first though
