Re: 656 carb
Posted by The tractor vet on January 01, 2013 at 19:14:08 from (76.212.230.32):
In Reply to: 656 carb posted by Josh Day on January 01, 2013 at 17:25:28:
That is not your problem as that is for shut down . As for the stumble there are several things that cause that , cold engine , ing. timing not set right , centrif. advance not working , heat riser not doing it job due to broken Bi metal spring or the maniflod is full of carbon and hea is not getting to the intake . As for the oil problem might be valve guieds , might be a plum slap wore out engine , Might be the gas your running . Can't say for sure as i am settinjg here at the idiot box not looking at your tractor.
