Re: F 14
Posted by Tom Fleming on January 02, 2013 at 02:53:38 from (67.20.233.75):
In Reply to: F 14 posted by James Williams on January 01, 2013 at 17:20:02:
Try squirting a little gasoline into the carb for first start to see if you get a different result. don't forget, these have a fuel pump and it takes a little to get fuel up to the carb.
However, you can also check the compression on each cylinder to see if you have a valve issue. If you run fine after it starts, I highly doubt you have a valve/compression/vacuum issue.
The other thing you can do is to open the carb float bowl drain valve to see if you have fuel in the bowl before your first start. Try these things first and let me know.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
