Posted by mkirsch on January 02, 2013 at 05:26:46 from (64.80.110.74):
In Reply to: 300 belt replacement posted by Lynn Kaufmann on January 01, 2013 at 20:31:38:
Clean up the threads on the water pump hub as best you can and lubricate them with your favorite penetrating oil.
There's a nut and set screw on the outer sheave of the water pump pulley. Find it and remove it.
Place a punch at an angle against one of the raised points on the outer sheave, and tap with a hammer to cause the sheave to rotate counter-clockwise on the pump hub. After a few taps the sheave should be loose enough to rotate by hand.
Even after the sheave is totally loose, the belt will be a tight squeeze over the crankshaft pulley, but it will come off. It will come off over the fan blades too, just do one blade at a time.
The easiest way to get the generator belt off is like Zach says, but it should have a similar pulley setup to the water pump.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
