Re: Help! I'm stumped - Farmall won't crank
Posted by Harold Hubbard on October 31, 2000 at 17:21:16 from (209.198.81.82):
In Reply to: Help! I'm stumped - Farmall won't crank posted by Keith Seymore on October 31, 2000 at 07:43:28:
If the A uses the same (expletive deleted) starter mounted switch that the C does, you should check to see if the contacts in it are still there, not badly pitted, and lined up properly whith each other. If the bolt that the cable hooks to spins when you tighten the nut it will misalign them.
Post A Followup
: Re: Re: Help! I'm stumped - Farmall won't crank
