Re: M trans trouble
Posted by F-Dean on January 02, 2013 at 16:58:58 from (70.193.199.35):
In Reply to: M trans trouble posted by justanothercase on January 02, 2013 at 16:50:32:
Take the pully drive off and look to see if you can tell what the problem is. Something may be causing the shifting forkks to bend.
