Posted by Lmack on January 02, 2013 at 18:25:48 from (24.131.58.167):
In Reply to: 230 water pump posted by tntleake on January 02, 2013 at 17:47:30:
The nut does not turn. You have to turn the 5/8" bolt on the front. The bolt on the back fits in a grove so that it will not turn at first. You can use one wrench to loosen the 5/8" until it has so much slop that the inside nut starts turning. You will need to use two wrenches at that point. It goes back the same way. At some point the rear nut will grip the grove and you will only need a wrench on the front nut. One of your other hands (I am serious) will be on the crow bar you are using to tension the belt. Use the rear nut as a lift point for the crow bar across the governor housing. Make sure the threads in the nut and on the shaft are clean. I would suggest running a tap into the nut and a threading die over the bolt threads. They need to turn easily and have a little oil when you reinstall. You have to get the 5/8" very tight or the fan pulley will simply drop down when it gets hot.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
