Re: BATTERY CUTOFF REVISIT
Posted by mkirsch on January 03, 2013 at 05:07:24 from (64.80.110.75):
In Reply to: BATTERY CUTOFF REVISIT posted by Bud W on January 02, 2013 at 06:17:12:
Safety protocol for working around and with batteries is to disconnect the ground post first, so you don't accidentally short out the battery against the frame of the vehicle.
For that reason I would recommend putting the cutout in the ground wire.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
