Posted by mkirsch on January 03, 2013 at 05:15:04 from (64.80.110.75):
In Reply to: 3rd hyd valve on 1066 posted by Jim W SEMN on January 02, 2013 at 19:32:13:
The power beyond is actually a plate that replaces the cover on the end of the valve stack on the 06 series tractors.
When IH came out with the 56 series, they did away with the end plate and made the cover part of the last valve in the stack. This continued through the 66 and most of the 86 series.
Not only do you have to buy the plate, but you also have to replace that valve body too. Then you have to buy a spool valve. So it's three times not cheap.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
