Re: Cub Compression Questions
Posted by El Toro on January 03, 2013 at 07:16:53 from (108.3.143.30):
In Reply to: Cub Compression Questions posted by equeen on January 02, 2013 at 20:59:28:
You need to check the fire to your sparkplugs should have a hot blue spark. Hold your hand over the throat of the carburetor while a helper makes an attempt to start the engine. Low suction means low intake manifold vacuum. If you have a distributor make sure you're getting battery voltage to your coil. With the ignition switch in the "on postition" and the points open you should have voltage on both small terminals on your coil. Take some 320 wet or dry and rub your points until they're shiny. Hal
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
