Posted by caterpillar guy on January 03, 2013 at 10:30:47 from (68.188.235.228):
In Reply to: 3rd hyd valve on 1066 posted by Jim W SEMN on January 02, 2013 at 19:32:13:
If you use a diverter valve you can run the auger that way with only 2 valves. And since you are gone be off the tractor anyway, it would not be hard to do. Just put a tee in the return line for the planter, and the auger. Then plumb the pressure lines to the diverter valve just push one way for planter the other for auger.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
