Re: Cub Compression Questions
Posted by equeen on January 03, 2013 at 17:51:34 from (209.102.248.236):
In Reply to: Cub Compression Questions posted by equeen on January 02, 2013 at 20:59:28:
The tractor is now running. It is magneto ignition.
Thanks VERY much for all the responses.
I was especially interested in the "clearance" question because for years I've been thinking that with all that cylinder cavity, etc. that there was lots of cavity for the ignition phase. Then I remembered that I had a head ground on an 8N and was told that as long as the piston didn't bump the head, without gasket, then there would be adequate clearance with gasket. Thus just thousands of an inch space between top of cylinder and head when ignition occurs. Heavy carbon build-up would reduce space even further.
Yes, we cleaned carbon off piston heads, valves and the head.
Son and I are happy campers to have this old engine running nicely even if the engine is essentially worn out. Good oil pressure as well.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
