Posted by Old Oly on January 03, 2013 at 19:55:51 from (63.233.158.131):
In Reply to: 3rd hyd valve on 1066 posted by Jim W SEMN on January 02, 2013 at 19:32:13:
Yes this can be done I added one on my 1206. I did this so I could use a grapple on my loader. You will need another middle valve block and lever. You will have to remanufacture your lever pivot tubes(for the 3rd lever added next to the seat).Need to do some clearance grinding on the left side seat mount casting and may not be able to use the original steel lines to your couplers(I used hoses).It is a snug fit getting everything out the back.Hope this helps.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
