Re: 1066 ihc
Posted by pete 23 on January 04, 2013 at 13:31:56 from (74.32.229.189):
In Reply to: 1066 ihc posted by patsjohndeeres on January 04, 2013 at 07:48:44:
NO, you cannot start it by towing. You can ONLY tow it short distance's safely if you put the range transmission in neutral. Not the speed ratio lever, the high, low lever. When range transmission is in neutral, no movement of the hydrostatic motor will occur when towing. If that is in gear, just moving it a few feet might rip the slippers right off the pistons on the hydrostatic motor.
