Re: 300 TA or clutch problem, I think
Posted by D Slater on January 04, 2013 at 17:05:40 from (184.15.46.232):
In Reply to: Re: 300 TA or clutch problem, I think posted by Zachary Hoyt on January 04, 2013 at 16:34:11:
If the transmission input shaft is messed up a double split is needed. If not and you can support things a split at the transmission will let you remove both lower and upper transmission shafts. Yes transmission work not much different than a H. PTO parts and the counter shaft is splined with all gears on it single gears is most of the difference. Unlike a H the counter shaft slides out of the gears to remove.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
