Re: lube fan pulley
Posted by Owen Aaland on January 05, 2013 at 01:15:34 from (216.47.35.211):
In Reply to: lube fan pulley posted by lonely chicken on January 04, 2013 at 05:36:20:
If you fill it with the fill opening horizontal it will be overfull and the excess oil will leak out. The fill opening has an internal stand pipe to set the correct level. fill with the opening facing up. Rotate it opening to the bottom and let the excess oil drain out and then install the plug.
If you leave it over full it won't hurt anything but can leave a mess as the excess oil leaks out.
