Re: Hydraulic piping
Posted by IH fan on January 05, 2013 at 07:59:38 from (108.220.170.72):
In Reply to: Hydraulic piping posted by Alderman on January 05, 2013 at 06:17:33:
1. On an H, you must be using a separate valve for the 3 point if you have a distributor mounted pump, right? Not the valve for the belly pump?
2. You will need either a "pressure beyond valve" for the 3 point if you want it to operate with the loader and still be able to use the loader, OR, you will need a flow divider valve to split flow for the 3 point and loader, but if you do this, one or the other, or both will be very slow.
IMO, you really don't have enough pump capacity to operate a loader, let alone the 3 point AND loader. Why is it you are not using the belly pump for the 3 point?
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
