Re: Hydraulic piping
Posted by DeltaRed on January 05, 2013 at 08:39:27 from (67.6.219.50):
In Reply to: Hydraulic piping posted by Alderman on January 05, 2013 at 06:17:33:
First you need to determine weather or not your tractor has the correct timing gears and drives to accomodate that pump.I am not sure weather or not an H and W6(M) use the same pump.You will need a 3spool valve.The 'mag' pump will be on the lower end of being adequate for your needs.You will also need an outside reservoir to have sufficent oil capacity.Imediatly/ASAP,remove the "plug" on the 3point cylinder.Replace it with a breather.On a plugged cylinder,you will have air lock,hydrolock,blown seals,other problems on a non vented cylinder.Oneway cylinders must be vented.
