Re: Is a Farmall LP worth buying?
Posted by Larry Hardesty on January 05, 2013 at 09:18:18 from (74.38.128.240):
In Reply to: Is a Farmall LP worth buying? posted by BigTone on January 04, 2013 at 14:57:00:
I had a Farmall 400 LP for 7-8 years. The oil always looked like it was changed yesterday. Had a bit more power than a gas or diesel. It is a bit of pain to fill up the tank on the tractor (need a wet line and a propane tank). You are not going to take a five gallon can of gas to the field to fill it when it runs out, so watch the fuel gauge. I had mine when I lived in Texas. I think they probably start better in warmer weather. They also stick a bit easier because they run so clean. I got mine cheap because it had stuck from sitting over the winter. It was real easy to unstick it. You do have to be careful around the propane. When you empty the wet line to take pressure off it, you shoot some propane out. Also, propane sure seemed to attract the flies when I was filling the tractor. I only sold the tractor because I moved. It was a good old workhorse.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
