Re: Frozen m
Posted by Janicholson on January 05, 2013 at 11:43:18 from (74.60.94.18):
In Reply to: Frozen m posted by Notjustair on January 05, 2013 at 10:49:04:
Make the tent as old suggests. An electric heater will do most of the work, as will the weather. The key is time. If given 3 hours or so, it will be liquid. Just drain the water and re insert rthe plug. (use rubber gloves as that water will be at 32 degrees.) there are two plugs that need attention, one under the finals, and one under the trans. Driving it will mix the water and oil making it impossible to remove as much. Jim
