Re: Voltage loss at the starter - Farmall M gas
Posted by Bob M on January 05, 2013 at 13:20:18 from (67.240.174.32):
In Reply to: Voltage loss at the starter - Farmall M gas posted by Scott Flynn on January 05, 2013 at 12:02:14:
A couple possibilities:
1 - The starter pinion is jammed in the ring gear.
If you can move the tractor, stick it in 5th gear then rock it BACKWARD and inch or two. If the starter is jammed a "clunk" from the starter as it is rocked means it has freed itself up. OR......loosen the starter mounting bolts and pull the starter part way out of the bell housing. Again a "clunk" will tell you when the pinion is again free.
2 - Your battery is low.
A good, fully-charged battery will show 12.6 at rest. Your reading of 12.2 (assuming your voltmeter is accurate) is somewhat low. Also your 3.8 volt reading under load is low - a good battery will show at least 8 - 9 volts with the starter engaged. Try charging the battery overnight, or better yet jump the tractor from a running vehicle.
