Re: Voltage loss at the starter - Farmall M gas
Posted by Matt in WA on January 05, 2013 at 14:00:01 from (70.199.234.154):
In Reply to: Voltage loss at the starter - Farmall M gas posted by Scott Flynn on January 05, 2013 at 12:02:14:
I agree with Bob. My 1950, Farmall M, gas, sticks the pinion on flywheel all the time. Especially, if battery low.
Take post off battery. Spin radiator fan 1-2 times in neutral, see if cranks. Otherwise, can take the 2, I believe 9/16" bolts , to unbolt starter to frame. Touch terminals of starter to battery only, not another vehicle, see if Bendix gear spins fast? Otherwise, if stored outside, fresh battery, always a good start. Also, is very likely original brushes in that starter? Fresh battery, + fresh starter eval. helps avoid lot of cranking. (Learned that hard way 5 years ago, on JD 4020).
Good Luck! Great tractor, mine runs great most of time. Don't get discouraged!
Matt
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
