try cranking it a couple times then.....CAREFULLY....feel the battery cables and ends to see if they are hot anywhere. if so, you have found your bad connection. on one of my m's, i had to run the ground directly to the mounting bolt on the starter . apparently, after 60 some odd years, the tractor chassis doesnt have a good ground path anymore.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
