Re: Frozen m
Posted by glennster on January 05, 2013 at 14:28:05 from (75.57.134.154):
In Reply to: Frozen m posted by Notjustair on January 05, 2013 at 10:49:04:
have at least 5 empty 5 gallon pails handy when you get it thawed. the rear end holds about 14 gallons of gear lube, and i learned that it can easily hold 6 gallons of water. also, keep a good hold on the drain plug. it is amazing how much oil dry is required for a major rear end oil spill. (dont drop the plug in the drain pail!!!) there should be a bunch of thick goo blocking the drain hole, use a wire to open it up. just an fyi!!
