Posted by David A. Allgire on January 05, 2013 at 16:11:30 from (96.35.208.3):
In Reply to: John M posted by James Williams on January 05, 2013 at 14:50:27:
James and John. I have 3 F-14's and 2 F-12's. I too had a little trouble adjusting the float level. The book says to adjust the fuel level to 23/32"-25/32" below bottom of upper body. That is slightly less than 3/4". But since 26/32"=3/4" I use that. The method I wound up using is to hold the top of the carb in its normal position. That is with the float hanging down. Using a ruler, not a tape measure, measure from the gasket lip of the top to the center of the float which should be 3/4". This method ensures you will have enough fuel in the float chamber even after installing the gasket between the top and bottom halves of the carb. I have not had to use two gaskets under the seat. All of my tractors will start on 2-3 pulls.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
